70mm Z71 Stage III Build
what happen to the video of your truck with the cutout open??
You my friend are a dream killer. I have a 12 sec truck but at least it sounds like a monster. I'm that guy that leaves a light side by side with you trying my hardest to keep the turbo in the sweet spot so its defining in your ear. Then at the last moment a little throttle dump and some compressor surge. lol
I dont know. lol. I dont see it on my youtube page. I had a nice one showing the difference between the full exhaust and open dump on the two step but its gone. Ill make another one when I get it back together.
Heres a vid where you kinda hear it. The diesel I was racing was stupid loud but when I bring the rpms up at the line, you can kinda hear my truck.
in car audio
in car audio
Motor is out, tore down to the short block. All the parts are in my garage or on their way.
Need to disassemble the engine
clean everything
bore hone
gap the rings
etc
I am able to rotate/move/slap the pistons in the cyls. As in up and down as the piston is TDC. Is that common or OK?
clean everything
bore hone
gap the rings
etc
How many sensors/gaskets do you guys change while this far into a rebuild.
sensors - crank sensor, knock sensors, coolant temp....
gaskets - oil pan gasket, intake manifold, oil pressure port...
Should I replace the ones that are beat up a bit or just replace everything?
clean everything
bore hone
gap the rings
etc
clean everything
bore hone
gap the rings
etc
the Pistons will move.
