70mm vs. 76mm turbo on 5.3
#21
Ok I need some help too! I have a 5.3 with the Z06 cam and springs with LS2 injectors. I wanna go turbo in My Suburban. I want to keep the towing ability and the stock torque converter! Will this work ok? T70 Turbo Charger Mustang Supra Civic Camaro+ 3" V-Band | eBay
#22
I think my turbo is sized perfectly for a 5.3... I can keep it out of boost at anytime, except when towing, yet the spool is very quick when I want it. It is a Q-trim 1.0a/r 70mm. A P-trim .96 70mm will spool significantly sooner and from less of a load on the engine, which isn't a bad thing. It really just depends on how you want the truck to act. If you did go with a 76mm, I would keep it at a .96 P-trim. You could even pick up a .81 a/r housing for it, to get things started a little quicker.
Inlet 4"
Outlet 2.5"
Bearing Wet Floating Bearings
Cooling Oil
Flange Standard T4
HP Rating 400-500 HP
Internal Wastegate None
Compressor .70 A/R Compressor
Turbine .96 A/R Turbine
Compressor Wheel 91mm/61mm
Turbine Wheel 74.7mm/62mm
Hot Side 3" V-band
Somebody said it was a 62mm due to the Turbine Wheel size. Is this true? It's advertised as a 70mm...
#26
the compressor side of the turbo pretty much just tells you how much air it can push into the motor, id be alot more concerned about the exhaust wheel size and ar, a 70mm can make 700hp. You don't want any more then a 1-1.5 back pressure ratio. I'd recommend a 75mm ex wheel with a .96 ar for a 600hp 5.3 and a 1.10 ar for anything over 700hp.
#28
I just swapped from an on 3 70mm .96 ar to a master power 76mm .96 ar. This is on a 5.3 with 317 heads, we don't have a dyno local here but its unbelievably different, and still running it at 14 psi. Guessing the on 3 turbos are just crappy to begin with.
#29
You should get a BW billet SXE S369 or S371 and it will blow that t70 out of the water!! lol Just need to have the discharge machined for a 3" vband and run a 1/2" spacer on the t4 inlet and will bolt right in to your pipes. Ask Rick about one, think he's got a 71 he should let you borrow... for testing! lol
#30
Who knows, I just got my Stage III completed, haven't gone WOT and already thinking about more power.
