70mm vs. 76mm turbo on 5.3
Old Jan 17, 2012 | 10:55 AM
02'Z71ONDUBZ''s Avatar
I think my turbo is sized perfectly for a 5.3... I can keep it out of boost at anytime, except when towing, yet the spool is very quick when I want it. It is a Q-trim 1.0a/r 70mm. A P-trim .96 70mm will spool significantly sooner and from less of a load on the engine, which isn't a bad thing. It really just depends on how you want the truck to act. If you did go with a 76mm, I would keep it at a .96 P-trim. You could even pick up a .81 a/r housing for it, to get things started a little quicker.
Old Jan 17, 2012 | 12:33 PM
M&M Turbochargers's Avatar
magnum p trim 64.5/74.2
Q trim 67/74.2
the outlet on the q trim is a little bigger
Old Jan 17, 2012 | 12:59 PM
foose04's Avatar
Good info in here. Both will work fine, but if it's a true DD i'd look into the 70. It will be there ready to come online at each street light if you ask. The 76 won't be to far behind it, but you'll be pushing the on the go pedal longer before it joins in. Both will meet your 500HP goal and have another 100HP+ potential.
Old Jan 17, 2012 | 01:24 PM
kazfan30's Avatar
Agreed... if I did not get my t76 for a steal..I would have went 70mm..power difference minimal and boost spool time is quicker.
Old Jan 17, 2012 | 05:15 PM
kbracing96's Avatar
You can also get a Magnum turbo in a 72mm compressor for a nice middle ground.
Old Jan 17, 2012 | 05:57 PM
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by devink
Like the title says. Which is more appropriate for a DD. I like 500 hp to the wheels with the possibility for growth. I am planning on an A2A intercooler.
Would a .96 AR be good for either turbo?
Thanks
Like others have said either will work. You can make 500 with a 62mm turbo. A 76mm gives you more room to grow then a 70mm will. You can always run a small a/r housing if its too lazy for you.
If you get a smaller a/r go ahead and buy the larger as well.
You will need it later in life.
Old Jan 17, 2012 | 07:06 PM
sprayedenali's Avatar
70mm w/ .96 ar..... You'll love it
Old Jan 17, 2012 | 11:21 PM
Alpinestar's Avatar
I've got the same cam as you and a similar stall converter. I would go with the 70mm .96 a/r if you plan on keeping your current cam.
Old Jan 18, 2012 | 01:07 AM
devink's Avatar
Wow. Tons of great info here. Thanks. Im on the fence regarding the 220 cam, i am worried it will bleed off too much boost. Alpinestar, if you had to do it over would you still go with the 220?
Old Jan 18, 2012 | 05:00 AM
blue0453's Avatar
I'm running Tr220, with a mp 76 96ar. Made 486 at a little under 10psi. Running 13psi now and it runs strong. I am considering swapping cams though to see if it makes a diff.
