60lb injectors on a TVS1900 ???
I have some custom ones up to 72lbs/hr for about $500.
these are the 60's used in the 2300 TVS, yours should have a spacer between the rails and mount bosses allowing your current injectors to fit. Replaceing them with the ones above should only require removing the spacers, and may also require injector pigtail adapters. The above pictured are Minitimer style ( only style avail in this size),there are two other injector plug styles Delphi and USCAR.
hope that helps.
If I recall correctly the pink injectors use the newer style plug which would be different from the Motron 60's. You'll need different adaptors, but you could use the Motron's or even just go to the 80lb hr (overkill for a blower that small) Ford Motorsport injectors. You could run E85 with them though. You might even consider looking for some ZR1 injectors.
Would these work?
SD tall 60lberrs
That's the best shot I've got of the stock injectors SRT10KLLR. Can anyone attest that these are infact the SRT-4 injectors? From what I gather, they are a tall USCAR style injector.
SD tall 60lberrs
Would these work?
SD tall 60lberrs
That's the best shot I've got of the stock injectors SRT10KLLR. Can anyone attest that these are in fact the SRT-4 injectors? From what I gather, they are a tall USCAR style injector.
SD tall 60lberrs
If you want more flow than those or want a flow matched set I can hook you up with sets from 50 to 72 lb/hr at 3 bar(43.5 PSI) with that same size and USCAR connector. If you want to go extreme you can go with the 80 lb/hr Ford injector or the 60 lb/hr Siemens with the USCAR connector.
BTW, I have a ton of those Purple/Pink SRT-4 injectors if anyone wants a set.
I just saw the injectors on your link. Those will definitely work as they have the USCAR(EV-6) connector and are the correct size(length) for you application plus they are pretty cheap too. If you want something that flows more let me know.
