6.2l or a new style 383 stroker motor
Old Jun 19, 2012 | 04:26 AM
TURBHOE's Avatar
So the issue isn't so much the motor as it is human error then. It seems there are a lot of boost 6.2's on tech. I can see hard to tune ECM causing issues.
Old Jun 19, 2012 | 11:09 AM
nicky g's Avatar
I think I'm gonna just build a 383 Stroker motor out of a 5.3 and build it for boost and install a D1 or maybe a Turbo don't know yet
Old Jun 19, 2012 | 01:26 PM
sand man's Avatar
tray to get a 6.0 youll get the best of two worlds
more displacemnet than the 5.3 and ready big bore , and youll start with a solid Iron block , i just cant trust almnium blocks as DD for anything over 15lbs
thats just me , I might be wrong but thats just me.
i bought an LY6 for the same reason insted of building my alumnium 5.3 to 383 after spining the bearing
also took the 6.0 for the obviously better flowing heads
the LY6 comes at 9.6:1 CR
as for having a good rotating, the stock GM crank holds its on , some went 1200hp on F bodys on the LS1tech and most guys saythe never had a problem staying arround 800hp so all you really need is new rods and pistons with balancing the crank shaft and get some SS valves , i think youll hit 18 PSI no problem
I never built a turbo motor but thats what i have been reading and seeing ppl do
thats what i plan on doing too
Old Jun 19, 2012 | 07:46 PM
nicky g's Avatar
This is a iron block 5.3
TXsilverado
Nov 26, 2015 10:54 AM
ss4chad
Aug 15, 2015 02:25 AM
Sdailey
Jul 13, 2015 09:17 PM
Sdailey
Jul 11, 2015 08:16 PM
Nimoryan
Jul 5, 2015 03:50 PM
