6.2 turbo build
#731
Thanks man! And the turbo is crazy mean sounding for sure. It's just get close to shining at 16lb. Like I said I'm going up to 20lb maybe 22lb plus race gas at the track for sure. And one thing I notice we were only reving the engine the 6300rpm I think it will make more power reving it to 6800 to 7000.
#732
When do you hit full boost? Your powerband is pretty linear.
#733
Boosted, with the converter I have it boost up on the foot brake. From idle around 2800rpm but man it dead on at anytime else. In fact on the Dyno at you get on the to low in the pull it ramp up so quick with the co2 it spins on the dyno. We was rolling in the throttle at 85mph to stop the spinning. The cam with just 4degree of overlap helps it spool too.
#734
Keep cranking it up!
#740
The 14 bolt is strong stock but I did install the tru trac.. But Im going to finish up some more suspension mods with poly control arm bush. I have them in the upper control arms and the rear leaf springs.
