6.2 turbo build
Old Dec 4, 2014 | 09:43 PM
  #631
TrickTurbo's Avatar
Truck Sponsor
Did you run your ground cable to both locations.
Frame, and all the way back to the block?
Old Dec 4, 2014 | 09:47 PM
  #632
Byrdman11's Avatar
The ground is on the frame in the rear and then from the frame to the stock cable that is on the cylinder heads.
Old Dec 4, 2014 | 09:51 PM
  #633
TrickTurbo's Avatar
Truck Sponsor
Ok. If you have any electrical glitches or ghosts.
Run another cable. For the ground side. Cable gives a cleaner ground then frames do.
Again only if you see intermittent problem.
Old Dec 6, 2014 | 07:40 AM
  #634
Byrdman11's Avatar
Rick, what can you do me a custom coolant tank for? I don't have time to be it. If I can get the stock one to look better moved back closer to the old battery box it gone!
Old Dec 6, 2014 | 11:07 PM
  #635
Byrdman11's Avatar
Well I almost got the fuel system done. The fuel system is twin 450's one is setup like it was powered by the stock FPCM and the other is setup powered by a hobby switch turn on the pump at 5lb of boost. I install a little line to fill the bucket too. 6.2 turbo build-image.jpg
Old Dec 6, 2014 | 11:08 PM
  #636
Byrdman11's Avatar
Old Dec 6, 2014 | 11:09 PM
  #637
Byrdman11's Avatar
Old Dec 6, 2014 | 11:10 PM
  #638
Byrdman11's Avatar
6.2 turbo build-image.jpgAttachment 72100
Old Dec 6, 2014 | 11:12 PM
  #639
Byrdman11's Avatar
6.2 turbo build-image.jpg I install a second one way check valve in the bucket to get more fuel in the bucket faster.
Old Dec 6, 2014 | 11:15 PM
  #640
Byrdman11's Avatar
