6.2 turbo build
Old 08-19-2012, 07:35 PM
  #31
pewterliftedz's Avatar
should spool nicely around half track
builds lookin real good man.
Old 08-20-2012, 10:04 PM
  #32
Byrdman11's Avatar
Tonight I install the fast injectors and the wastegate springs for 7.5lb hoping to be close to 8lb of boost and use controller from there.
Old 08-26-2012, 08:44 PM
  #33
Byrdman11's Avatar
Working on the Downpipe and crossover. Downpipe is touching firewall heat shield and I worked it out a little. Install oil feed too. And also cover the fender well where the downpipe get close. Dont want anything melting you know. Pics coming. get close to firing it up.
Old 08-26-2012, 09:36 PM
  #34
Truck Sponsor
TrickTurbo's Avatar
Yea the heat shield right at the bend some times needs a little love'n with a hammer on the shield. Also there could be a stud sticking down holding the heat shield. Right in the middle. Cut off the extra is needed.
Old 08-27-2012, 07:51 AM
  #35
Byrdman11's Avatar
Thanks Rick I will do.
Old 08-27-2012, 02:47 PM
  #36
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
I really like that tank Trick sells.
Old 08-27-2012, 04:02 PM
  #37
Byrdman11's Avatar
Yes, it worked out awesome. Drilled two hole to mount tank to plate and cut one square hole in fender. Fits like a glove.
Old 08-28-2012, 08:56 PM
  #38
Byrdman11's Avatar
I finished the exhaust to the downpipe and install the wastegate. Next the drain fitting in the pan and finish up the wiring for the meth system. I want it finish this saturday so I can go to the dyno soon.
Old 08-30-2012, 09:37 PM
  #39
Byrdman11's Avatar
I firing it up tonight running great no leak all is good. 6.2 turbo build-img_0992.jpg
Old 08-30-2012, 09:40 PM
  #40
Byrdman11's Avatar
O, I went with the sunpro boost gauge because I think it looked the closest to my air/fuel gauge. I'm still thinking on the gauge thing.... 6.2 turbo build-img_0997.jpg
Quick Reply: 6.2 turbo build
