6.2 turbo build
#533
Truck Sponsor
Mark that's what Lightning owners have done for years.
The one I seem in my shop you could easily fab up with your skills.
It use angle bar to build the battery box.
Then see if you can build a side off the frame or hang it from the frame.
Making sure to allow room to remove and not touch terminals.
#534
Rick I have a battery mount. I'm thinking of use the same one I use in drag car builds. The easiest place would be in front of the pass rear tire on the frame. But I really want it behind the tire. The leaf spring is in the way but I could remove the spare tire and install the battery in its place. What you think????
#535
Yes remove spare tire. Put it in its place.
#536
Truck Sponsor
Any room between tire and frame. I haven't had a chance to look under my truck yet.
#540
Got a few more things done, ran lines from gate to turbo and boost controller and install oil pressure flange on turbo. I went to install the new injectors in the intake before installing it and wish, wrong injectors. So Im waiting on parts again but maybe the exhaust tubing will make it so I can start building the new exhaust.
