6.0L w/ oil cooler on the block, turbo oil feed question
Old Oct 20, 2012 | 05:51 PM
TXjeepTJ's Avatar
Default 6.0L w/ oil cooler on the block, turbo oil feed question
I bought a 6.0L to drop in place of my 5.3
It came with the oil cooler adapter piece. I do not want to run this, I want to run it howout I had it with the 5.3- which was using the drilled/tapped out piece above the oil filter. Could I just put on my old drilled/tapped piece on there? or since it was setup for an oil cooler will there be complications with this? I see there are two ports on the block, one must be pressurized while the other is a return line. Do I need to block off the return line to prevent a pressure loss?
Old Oct 20, 2012 | 06:49 PM
Atomic's Avatar
I have a gauge for that
You can put your old taped cover on there. Your 5.3 block was exactly the same. Both ports are pressurized.
chopperloco
Jul 10, 2016 10:45 PM
D1SCSS
Jan 25, 2016 10:14 PM
Noah Burns
Sep 7, 2015 05:50 PM
ullose272
11
Jul 17, 2015 07:22 AM
Mzay
Jul 6, 2015 11:03 PM
