6.0 2500HD boosted for towing TURBO recomendations.
Old 10-20-2017, 07:54 PM
LPCWS6's Avatar
Not sure why you can't tow with a gas turbo. The ecoboost kicks the crap out everything from GM and Dodge in this.
TFLtruck - Hall of Ike Gauntlet - The Fast Lane Truck
Old 10-23-2017, 07:25 AM
Truck Sponsor
TrickTurbo's Avatar
You can pull with a gas turbo.
But the system needs to be set up to haul loads.
One turbo might make 700hp on a gas engine. But that same turbo might be wrong for pulling.
Just depends on how it's all set up.
Old 10-28-2017, 11:20 AM
Dynospeed's Avatar
The turbo can work for you really well. Defiantly don't go to small especially on the turbine you need to keep it efficient. A 7675 would be the absolute smallest turbine and it would build a few psi under 2800 RPM's loaded climbing the hill. 3 psi will make a big difference lugging up that hill. Run a proper size wastegate to keep boost in line.
Old 10-28-2017, 01:06 PM
3wide's Avatar
"So i have an 04 2500HD CCSB with he 6.0 gas 4L80E . It spends 90% of its time with either a plow in front of it or a trailer behind it"
This say's it all= get a supercharger it will give you more low end than a turbo with just a bolt on.
