5.3L Turbo Dyno Numbers
Old Jul 21, 2005 | 11:14 AM
Default 5.3L Turbo Dyno Numbers
We had a chance to dyno a 2003 5.3L Silverado with the Detroit Speedworks Turbo Kit and the base GT-37 turbo. I figured I'd post the results since it's been asked several times, how much power the base kit makes. The truck was fairly stock with the only mods being a Gibson Catback and 4.56 gear. I wish we could have baselined it, but the kit was installed by the customer. I've seen similar stock 5.3L trucks make 225 rwhp / 285 rwtq (some may make a little more, some less).
It made 379 rwhp and 450 rwtq at approximately 6.5-7 lbs of boost.
-Rick
Old Jul 21, 2005 | 11:20 AM
XLR8NSS's Avatar
Adkoonerstrator
Hmmm....sounds interesting.
Old Jul 21, 2005 | 12:06 PM
14 Second Truck Club
You have RPM for those numbers, specifically the torque. They look really good.
Old Jul 21, 2005 | 12:10 PM
BlownChevy's Avatar
blownerator
25 Year Member
Sounds like some good numbers....I would have expected 400 rwhp or so at that boost level though.
Old Jul 21, 2005 | 12:13 PM
2k5Squirrel's Avatar
and that's from the stock kit? what brand dyno was it on? sounds pretty impressive to me.
Old Jul 21, 2005 | 12:38 PM
Scream's Avatar
MOOBIES Moderator
Excuse my ignorance, but would the 4.56's make any difference in the numbers?
Old Jul 21, 2005 | 12:42 PM
These numbers were on the Dyno-Jet and it made max torque at about 4,100 rpms, however I think the large gear changes the powerband. Max hp was around 4,700 rpms.
-Rick
Old Jul 21, 2005 | 12:44 PM
Bigger gears usually show lower dyno numbers.
-Rick
Old Jul 21, 2005 | 01:41 PM
v8
17,16,15,14,13,12,11 Drvr
well how does it do in the 1/4, im not a big fan of dynos! I was allways under the impression turbos needed higher gear ratio like 323 0r 308,342 but 4.56 that seems to put not alot of strain on the turbo that it needs or am i wrong? thanks for the help and nice #'s there.
Old Jul 21, 2005 | 02:03 PM
Not sure about 1/4 mile numbers, it just got done today. I would assume it should run pretty good, because it was a regular cab short box.
The Escalade with the same kit weighing 6,055 lbs went 14.2@95 mph at 5 lbs. of boost and 12.88 @ 107 mph with a bad trans and the upgraded GT-67 and 13-14 lbs. of boost.
Below is a video of the Escalade. As you'll see, I was sleeping at the tree and he got me off the line pretty bad. I launched at 3 lbs. and at the 53 second mark in the video you will see the truck torque steer to the right and I let out and get back in it. You'll also hear the stock trans not liking the added power at the 59 second mark, once again I let out for a moment so it would shift and got back in it.
You'll see us doing some testing at the shop, and then the race. (It's loud with an open down pipe)
Escalade 12.88 Pass
and Harlan's Silverado with the GT-67 at approx 12 lbs.
Silverado Video
-Rick
