5.3 radix build
Old Dec 26, 2009 | 10:29 PM
  #31
moregrip's Avatar
what a rush!
Originally Posted by Blownme
Thanks grip, waiting to hear from blownchevy. I guess no one has ever done that. Would it be better to build a forged 6.0. I was just looking at pulling my 5.3 and building it all forged and using a stroker ls1 kit. Want to eventually run a shot of nitrous as well.
that's essentially what it would end up being but with an iron block instead of an aluminum block; saves you the cost and trouble of locating a different block
Old Dec 27, 2009 | 12:59 AM
  #32
LsxCody's Avatar
lots of ppl have bored the 5.3 out, with new internals and make a 346
Old Dec 27, 2009 | 01:27 AM
  #33
dirt track racer 81's Avatar
Theres quite a few around Ive built 2 iron ls1s, one was forged, fixin to start on an iron 383
Old Dec 27, 2009 | 08:03 AM
  #34
guero68's Avatar
no steal steal your thread..but i am building a 08 5.3 with a TVS1900 ARH 1 7/8w/cat and 224/230 114 cam DOD delete. The kit i got cam with 42lb injectors and i was wondering what i should buy first...starting to run low on funds after buy everything...
meth kit or 60lb injectors....and i still need to get a higher stall converter going with Circle D
Old Dec 27, 2009 | 11:43 AM
  #35
Blownme's Avatar
I did'nt mean to word it that way of no one ever boring a 5.3. I've just seen were most people ditch the 5.3 and go with the 6.0. Anyways, I'm looking at the two stroker kits one says 346 and the other a 383. How far can i go on the 5.3 block bore and stroke wise? Also I am going to port and polish the heads or would it be better to run a different set of heads. I am still going to run the mp112, may uprade to the tvs later.
Old Dec 27, 2009 | 11:59 AM
  #36
moregrip's Avatar
what a rush!
the 346 is bore only, the 383 is bore and stroke
Old Dec 27, 2009 | 03:26 PM
  #37
AKlowriderZ71's Avatar
11 Second Hall Moniter
I think that if you are planning to build a 383, you should consider a larger blower than the 112. The 122 or a TVS series would be better suited for the larger cubes.
Just my opinion.
Old Dec 27, 2009 | 04:30 PM
  #38
Blownme's Avatar
Will the 112 work with a bore to 346?
Old Dec 27, 2009 | 04:41 PM
  #39
moregrip's Avatar
what a rush!
it will work fine on either engine. If that's what you have that's what you should use unless you want to spend the $$ upgrading the blower as well.
Old Dec 27, 2009 | 05:13 PM
  #40
I would use the 112 on a 346.
