5.3 radix build
Old Dec 15, 2009 | 06:19 PM
Blownme's Avatar
you guy's are awesome for all the help. The guy(ED Wright fastchip automotive) that will be doing my dyno tune is backed up for a couple month's. So it will give me time to get some mods in order. What size pulley would you recommend for the exhaust. I'm going LT, no cats, and probably magnaflow muffler. I currently have a transgo shiftkit intalled in my 4l60 it seems to be doing well. When i hit second at about half to 3/4 throttle it'll chirp the tires. Traction is the main issue for me fight know.
Old Dec 15, 2009 | 06:22 PM
moregrip's Avatar
what a rush!
maybe some traction bars to help with the axle wrap
Old Dec 15, 2009 | 06:35 PM
old motorhead's Avatar
Go long tubes and 3" duals all the way back to twin straight thru mufflers (magnaflows are my choice). A good exhaust lowers boost, which lowers temps, which makes more power available. A good free flowing exhaust is pretty much easy hp. It just maximizes everything else you do. You can probably do a 3" pulley or even a 2.8" with a mild blower cam. The 5.3L will make a lot of power and live a long life if you do it right.
Old Dec 15, 2009 | 07:32 PM
SILVERADO11's Avatar
I would recomend saving for a new trans as well, my stock 60E lasted only 14k miles with the maggie 112. and thats total miles on the trans. I had not found this site yet so i put another stocker in and its starting to slip another 15K later. almost have enough saved up for a FLT trans thay are a sponser to the right>>>>>>>>>>>>>>>>>>>>>>
Old Dec 15, 2009 | 07:40 PM
Blownme's Avatar
What tranny should I upgrade to when it does go.
Old Dec 15, 2009 | 07:42 PM
Blownme's Avatar
Also what is the difference in the Gt2-3 cam and the Vinci trucker
Old Dec 15, 2009 | 07:54 PM
well i am going to go with the FLT Level 7 4L65E with a Yank SC3000 converter, i like to over build if i can. I would give FLT a call with any questions you have they are very helpful.
Old Dec 15, 2009 | 08:20 PM
terravast4's Avatar
Ed did my tune and not completely happy with it. Try wheatly or nelson tuning here as sponsors. Where are you from?
Old Dec 15, 2009 | 08:32 PM
Blownme's Avatar
Tulsa, OK . I thought Ed was supposed to be one of best around. So Wheatly and Nelson are better. would that be mail order tune
Old Dec 15, 2009 | 08:38 PM
dewmanshu's Avatar
Moderately Differentiated
LOL..yeah good site for research on a maggy 112 setup on chevy truck.
First things first...if you want more power out of the setup you have, you need to start thinking about the trans like others have pointed out. That car trans is not gonna do the trick in stock form (80% of the time). Putting a lot of money in the setup and then being without a trans will **** you off big time.
Welcome to the site! Hide your credit cards and cash!!!! Wheatly, Nelson, and Black Bear tuning shops are very very familiar with your setup and can hook you up better than the fore mentioned tuner for a lot less in the long run.
