5.3 radix build
Old Dec 14, 2009 | 09:57 PM
Blownme's Avatar
Default 5.3 radix build
I'm new to the forum and I look forward to learning all that I can. I just recently installed the mp112 on my 5.3 2004 silverado. I like it very much but would love to gain the most power possible from the system. I'm basically stock except for volant cai and flowmaster muffler. I plan on headers and full exhaust with magnaflow's. Maybe a cam and pulley as well, not sure about the pulley because the guy's at magnacharger told me the 3.2 pulley that I have is plenty enough boost. Although i see most guy's on the forum running a smaller pulley. Also a custom tune in the future as well. Any feed back on how gain the most from the 112 would be greatly appreciated!!
Old Dec 14, 2009 | 10:41 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
welcome to PT. Your going to see a big improvement just with a good tune. The 3.2" pulley is giving you close to 8lbs, plenty. A better flowing exhaust will drop boost but increase hp. Lots of great info here. Click my sig pic and read my pages if you like.
Old Dec 14, 2009 | 10:46 PM
Pooki's Avatar
Agreed 100% with trever1t. Getting a good tune on it will most likely be the best thing you could do for your set up. You will end up being very close to my set up I am guessing. Im running 9-10lbs with the 3.2 and MP122. I would like a bit more but dont think the stock 5.3 will take it. Welcome to the forum.
Old Dec 15, 2009 | 02:46 PM
Blownme's Avatar
Thanx for the input I will definately be putting on headers and possibly the Gt2-3 cam and then get a tune. My other question, is there a cam that will produce the same power as the gt2-3 but have choppier idle? And also if I lose boost with the headers and exhaust will I need to drop a pulley size to compinsate?
Old Dec 15, 2009 | 03:20 PM
trever1t's Avatar
boost is a measure of restriction, compressed air/fuel in the manifold-not the cylinder. Removing exhaust restrictions lowers measured boost but increases output very nicely. Yes, you can go to a smaller pulley for even more power
Old Dec 15, 2009 | 04:00 PM
03tahoe22's Avatar
There are alot of tricks to the maggie setups.... 90mm throttlebody conversion. Methanol. Larger heat exchanger.... $$$$$$$
Old Dec 15, 2009 | 04:06 PM
Atomic's Avatar
I have a gauge for that
Good boost cams do not have choppy idles. The choppiness comes from the close lobe separation. The Gt2-3 is 118.5, which is quite wide, and is also why its good for superchargers.
Old Dec 15, 2009 | 04:53 PM
TX Tahoe Z71's Avatar
And heat is a big problem with the 112's, so if/when you pulley down, you need to keep it cool. I went with the CTS-V heat exchanger and volant ram air to help combat this.
Also make sure you have the supporting mods as you increase horsepower, like tune, injectors, fuel pump or boost-a-pump, headers, tune, and tune.
There are a bunch of Maggie's in here, so the search button can be your best friend
Old Dec 15, 2009 | 06:07 PM
old motorhead's Avatar
Go ahead and plan the funeral for your '60 tranny. I can see from here that it is not long for this world. Enjoy, but beware
Old Dec 15, 2009 | 06:13 PM
yeah, that too. 40k tranny cooler, corvette servos, maybe even a HD2 shift kit will help delay the inevitable
