5.3 + maggie 122 + 90MM tb = good or not???
Old Sep 30, 2008 | 02:09 PM
  #21
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by hellbents10
Run that 112 at 500whp around a road coarse once lol. One of two things will happen.
One, it runs a incredibly slow considering the 500whp dyno sheet because you have it tuned correctly and its pulling timing when the IAT's are at 200+ degrees.
Two, it melts the engine down because it rattles itself to death.
I can make a 112 hit 500whp on the dyno too after a cool down. Make it repeat itself after 3 back to back pulls like a properly supercharged or turbocharged car and then I will be impressed.
Ok I will see your road course and raise you one smoked porsche. Next?>
http://videos.streetfire.net/video/H...-Vs_165902.htm
Excuse the fact that he smoked a purpose built race car, I am just showing you that the MP112 Magna Charger will and DOES perform on the road course. FYI, that car has over 6000 track miles on it.
Your claims have holes in them....There are plenty of people that see, back to back, to back results in the 500+ rwhp area.
Old Sep 30, 2008 | 02:21 PM
  #22
dewmanshu's Avatar
Moderately Differentiated
Old Sep 30, 2008 | 02:23 PM
  #23
hellbents10's Avatar
LS1Tech Sponsor
K, all I keep hearing is how the power potential has no ends to it with these things but never see or feel anything but tremendous amounts of heat.
They do work awesome to a point but this person wanted to know if he should go with a 112 or a 122 when he has plans to up the cubes down the road. Sorry a 112 shouldn't be on a decent flowing 6l trying to make 10+psi. They work awesome to a point, just seems to me everyone thinks that they are good for 400+ci engines lol.
Old Sep 30, 2008 | 02:32 PM
  #24
BlownChevy's Avatar
blownerator
25 Year Member
Like other adders, they all have their limit right? The proper sized turbo for the right job will work better than a little turbo on a big engine? A 112 will pump 6 psi efficiently to a 400Ci motor if needed, and a 122 will pump 10 or 15, the 1900 will give it 20 or 25 and the 2300 will pump in 30 + psi. If you want to play with the big boys, we could do a twin 2300 system and pump 50 psi into your 500ci or bigger motor?
To answer the original posters question with some educated information, with your current combination 5.3/4L80-E I would suggest a MP122 with a spot on calibration. Remember the more pressure you pump into a STOCK motor the more of a risk you are taking. I don't care WHAT you are using for FI if you are running the higher boost pressures, your calibration better be dead nuts perfect.
Old Sep 30, 2008 | 02:45 PM
  #25
LS1Tech Sponsor
Right on, I just get a little tweaked when people state that the maggie should be put on a wild 454 lsx and it will work great lol.
Its not that I hate these blowers. In the right application I love tuning them. Here is a buggy I did with a stock cam only 5.3l with a 122 and a 3" pulley.
Old Sep 30, 2008 | 02:46 PM
  #26
LS1Tech Sponsor
BTW don't mind the pulley in the pic that was the big one we used on the start up tune.
Old Sep 30, 2008 | 02:51 PM
  #27
Last Call's Avatar
TOTM: January 2007
With alky?
Yes. Straight meth.
Old Sep 30, 2008 | 02:56 PM
  #28
trever1t's Avatar
2nd fastest 5.3 ECSB
ZzzzzZZzzz a little slow there J
I think the M112 and the 5.3L are a near perfect match and still efficient enough for a 5.7
Old Sep 30, 2008 | 03:08 PM
  #29
SimpleManLance's Avatar
thats what i was thinking. is there a 6.0l on here making 10psi?
im not tring to knock the 112 at all.
im only wanting to run 9-10 PSI on a stock 5.3 with room to upgrade motor and boost. so what is the difference between 9-10 psi on on a 122 or a 112? and by calibration your talking about tunning right? to make 10Psi on a stock 5.3 with a 112 what pulley would you need? what pulley would you need on a 122?
Old Sep 30, 2008 | 03:10 PM
  #30
trever1t's Avatar
I make a little over 10psi with a 3" pulley but I have 243 heads and free flowing exhaust and a 90mm intake.
