400+ ci turbo options
Old May 8, 2014 | 09:55 AM
thewrx's Avatar
Default 400+ ci turbo options
I recently pulled my motor (lsx 376 stroked to a 416) to get it freshened up and looking to drop the D1 and go big turbo. I really want to keep the large cubes but starting to notice it requires an entirely different level of turbo. I want to make between 1000-1200 in full street trim and will drive this truck around to car shows, work, and maybe a short road trip. My goal is basically to run a single digit et at full weight or close to full weight. Should I go back to the 376 and go with the 80 mm snails or should I stay with my cubes and go with a 500 series frame or 90-100+ mm? Thoughts?
Old May 8, 2014 | 10:03 AM
smokeshow's Avatar
Mod with training wheels
Buy the 84mm in the for sale section here. I can't use it, otherwise I would buy it lol.
Old May 8, 2014 | 12:24 PM
thewrx's Avatar
too small.
Old May 8, 2014 | 01:30 PM
TrickTurbo's Avatar
Truck Sponsor
You have some option.
The 400+ is gonna require a large T6 with a big exhaust wheel.
Compressor side a billet 84 or larger will do.
Precision has some large cast stuff that can get the job done.
4" down pipe
Maybe Quick spool valve if spool rate was a little slower then you want.
And you'd be golden.
Old May 8, 2014 | 03:27 PM
smokeshow's Avatar
Originally Posted by thewrx
too small.
I see. Well in that case, get a 100mm+ turbo just to say you have a 100mm+ turbo. It's all the rage.
Old May 8, 2014 | 05:05 PM
Atomic's Avatar
I have a gauge for that
My 82mm does about 1150-1200 on my 402...guess its too small to have fun with :/
Old May 8, 2014 | 10:44 PM
boostedsl2's Avatar
80 mm flows 120 lb/min.....
Old May 8, 2014 | 10:52 PM
GMCtrk's Avatar
The trend in turbos is following the same trajectory as LS camshafts. Bigger and bigger then the bubble pops.
Old May 8, 2014 | 10:54 PM
TrickTurbo's Avatar
Truck Sponsor
A turbo that is slightly undersized (from what charts say)
will always be more fun in the street truck then one that is perfectly size or even to large.
Old May 8, 2014 | 11:01 PM
smokeshow's Avatar
It has to, otherwise nobody would be able to make any power.
