400+ ci turbo options
I recently pulled my motor (lsx 376 stroked to a 416) to get it freshened up and looking to drop the D1 and go big turbo. I really want to keep the large cubes but starting to notice it requires an entirely different level of turbo. I want to make between 1000-1200 in full street trim and will drive this truck around to car shows, work, and maybe a short road trip. My goal is basically to run a single digit et at full weight or close to full weight. Should I go back to the 376 and go with the 80 mm snails or should I stay with my cubes and go with a 500 series frame or 90-100+ mm? Thoughts?
You have some option.
The 400+ is gonna require a large T6 with a big exhaust wheel.
Compressor side a billet 84 or larger will do.
Precision has some large cast stuff that can get the job done.
4" down pipe
Maybe Quick spool valve if spool rate was a little slower then you want.
And you'd be golden.
4" down pipe
