4 days = 4 belts gone
Old Dec 6, 2008 | 09:12 PM
PSM's Avatar
PSM
Default 4 days = 4 belts gone
This is getting to be ridiculous.... I have the 100mm metco's already installed and I'm ordering a upgraded tensioner. Its tossed both gates and gatorback belts. I can't be driving it too hard... thats what its made for... Grrrr maybe you turbo guys had a point. If the tensioner doesn't fix this.. I must have a pulley that is misaligned
Old Dec 6, 2008 | 09:14 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
i've thrown one once....getting that fugger back on without tools was a bear! I tossed mine when hitting it hard and then letting out. What are you doing when it fly's?
Old Dec 6, 2008 | 09:16 PM
PSM's Avatar
PSM
Hit it real hard and it goes on a shift... or when i hit it hard and then let off
Old Dec 6, 2008 | 09:20 PM
BlownChevy's Avatar
blownerator
25 Year Member
Metcos are the problem.
Old Dec 6, 2008 | 09:21 PM
PSM's Avatar
PSM
hmmm well i bought the kit used... is there another set of idlers I can use that are bigger than the stock ones.. else I'll just order the stock ones
Old Dec 6, 2008 | 09:22 PM
BlownChevy's Avatar
blownerator
25 Year Member
have you tried just using the stock idlers?
Old Dec 6, 2008 | 09:23 PM
PSM's Avatar
PSM
I would.. but I don't have them since I bought the kit used and it came with the metco's
Old Dec 6, 2008 | 09:25 PM
BlownChevy's Avatar
blownerator
25 Year Member
I have seen more issues with the metco's than they are worth. not to mention they do not do anything.
Old Dec 6, 2008 | 09:26 PM
PSM's Avatar
PSM
what about them causes the issues.. are they not true so they cause the belt to walk?
Old Dec 6, 2008 | 09:28 PM
BlownChevy's Avatar
blownerator
25 Year Member
bearings used in them are garbage.
