4.8L 80mm Single Dirty Grandpa Truck Build
Old Jan 12, 2015 | 10:29 PM
  #331
Sevex's Avatar
Snail Fab
What OS do you have in your truck/car right now? That 12212156 OS does have a 4L80e (from the hp tuners repository), so if that's your base tune, you shouldn't have to do a segment swap. I would assume that you have to do the wiring to get it to work.
If you're using a different existing tune it'll need to have the same OS (12212156). You can find it by opening up VCM editor -> Calibration details. the OS is the "VCM OS ID: .........."
I am unsure what the current OS is on the truck, have not scanned it yet. So whatever the stock OS was is what's still in it.
I was just going to do a write entire with a tune with a 12212156 OS that already had a 4l80 and then just do the wiring mods needed. My biggest concern was if my PCM would take the tune, and then be upgradable to a 3bar OS.
Old Jan 13, 2015 | 12:11 AM
  #332
08DenaliT's Avatar
Hey when you where welding the flange did you weld the inside before you ported and cleaned them? That's where I'm at with my manifolds just wanted to ask.
Old Jan 14, 2015 | 07:26 AM
  #333
boostedsl2's Avatar
Cool. That's what I'm doing. I haven't confirmed yet and won't know for sure for probably a week. All the info I have says it should be fine but I hate to say "yes", you license and it doesn't work lol. I'll post back probably next week with my findings.
http://www.hptuners.com/forum/showth...-with-4L80e-OS
"If you were going to license another OS I would have at least used the newer 2002 12212156 base operating system as it was the most universally used among all GM vehicles."
Old Jan 14, 2015 | 07:33 AM
  #334
boostedsl2's Avatar
I have done it before but I usually don't. Can't remember what I did on my set. I get a little nervous welding flanges not bolted up to a jig due to the flange warping. Usually it won't move very much if it's already welded on the outside. If you're going to do it just make sure to do it quick. Keep as much heat out of the flange as you can. I would say 95% of the manifolds I've built I haven't welded the inside and they hold up fine. I've never had to fix a weld at the flange. I've built at least 40 manifolds.
Old Jan 14, 2015 | 10:00 AM
  #335
08DenaliT's Avatar
Ok awesome thanks alot I'm just gonna grind them down then and not weld it then.
Old Jan 14, 2015 | 10:07 AM
  #336
boostedsl2's Avatar
You're welcome. That's the route I would go.
Old Jan 14, 2015 | 10:25 AM
  #337
boostedsl2's Avatar
I've been working on straightening out the vacuum lines. Stock intake, extra sensors and the stock harness are a mess. Not an easy way to make it look decent so I figured I'd at least make a few brackets. Also needed a mounting spot for a flex trans dipstick.
Driveshaft showed up last night!! woohoo!
4.00x0.125 6061-T6 DOM with Spicer XL U-joints (1350)
Also got a replacement trans slip yoke to replace the 3R U joint yoke I had before and I got a 1350 pinion yoke.
I can't say enough how great the service is at Driveshaft Specialist Inc, out of San Antonio. Very helpful with planning (probably had 20 emails), very responsive, great price and the build time was 3 days from time of order. I ordered last tuesday and it was at my door here in FL 5 business days later. That is bad ***.
Jeff Dusek is who helped me. not sure if they are a vendor on here, so PM me for his details if you're interested.
I plan on swaping the pinion yoke tonight and fitting the driveshaft. Have my fingers crossed.
Here's some pics
Old Jan 14, 2015 | 11:07 AM
  #338
Vortec350ss's Avatar
Everything looks great. I went with a 4" steel driveshaft but I have debated swapping to aluminum a few times. The bracket for the vacuum lines looks great too.
Old Jan 14, 2015 | 11:44 AM
  #339
Atomic's Avatar
I have a gauge for that
Ive bought 3 or 4 driveshafts from them and they have been great to deal with.
Old Jan 14, 2015 | 11:52 AM
  #340
GMCtrk's Avatar
1 pc or 2 pc?
