4.8L 80mm Single Dirty Grandpa Truck Build
Old Mar 3, 2014 | 07:07 AM
  #91
6.0l RST's Avatar
sooo uhhh. ur fab work is amazing... wannna make me some!? haha
Old Mar 3, 2014 | 07:29 AM
  #92
Atomic's Avatar
I have a gauge for that
Originally Posted by boostedsl2
If anyone is wondering why I put the drain 10 an fitting so low it's because it's a pain in the *** to tighten a nut that needs a 1" wrench between 2 housings. I strongly suggest doing this on any turbo setup. Took me a few years to figure that one out lol.
I did the same thing on mine but just used a 1/2 npt pipe from home depot
Old Mar 3, 2014 | 09:19 PM
  #93
boostedsl2's Avatar
That'll do it too. It's the little things that make a build nice. It's should be easy to take apart as well as make power.
Old Mar 3, 2014 | 09:20 PM
  #94
boostedsl2's Avatar
Thanks. Not sure if I'll be building much after this for a while. It's a little draining.
Old Mar 3, 2014 | 10:06 PM
  #95
Atomic's Avatar
I also put one on the top after a brass fitting broke off in the turbo cartridge. Now it's a steel pipes I can get to the fitting at a flat 90 degrees.
Old Mar 4, 2014 | 12:17 PM
  #96
boostedsl2's Avatar
I gave up on brass a long time ago. I typically only use zinc plated steel on npt's. Stainless works too but will cross thread pretty easy.
Old Mar 4, 2014 | 12:38 PM
  #97
Vortec350ss's Avatar
This thread blows my mind.
Great work.
Old Mar 5, 2014 | 08:27 AM
  #98
boostedsl2's Avatar
Great work.
Thanks. Glad you guys are liking the build. Hopefully going to button up the exhaust this weekend. My buddy is flying in for a couple of weeks to help finish up, tune and drink beer.
Old Mar 10, 2014 | 11:38 PM
  #99
idahoblkss's Avatar
WOW ! where were you last year when i was looking for someone to make some hot pipes ... bout time somebody puts some skill into some hot pipes around here!! great job!
Old Mar 12, 2014 | 11:44 AM
  #100
boostedsl2's Avatar
Thanks!
So I'm about 99% done. hopefully going to drive under boost this evening. I'll post pics of progress in the next couple days.
I built/installed my 4" turbo back side exit exhaust. I bought a huge muffler to quiet it down. My wife was complaining about the noise on a 3" magnaflow.
So we cranked it up the other night..... the quietest exhaust I've ever built. you can hear the valve train over the exhaust. I am running atmosphere dumps so this should get pretty interesting on the street
Muffler is a DynoMax Ultra Flow Welded Muffler - 17557
The in/out are straight perforated pipe offset on their respective sides. They both enter a common chamber in the middle. It's not technically "straight through" but there isn't any baffling. You can look down one pipe and see light from the other.
Here's a short little vid.
http://youtu.be/ipchumUXDjo
