4.8 Turbo upgrade questions
Old Sep 11, 2014 | 08:00 PM
Sixshooter44's Avatar
How would a bw 467.7 with a 1.24 t4 housing work? Should spool super fast.
Old Sep 11, 2014 | 09:20 PM
Atomic's Avatar
I have a gauge for that
Dont think in terms of boost think in terms of air flow. A bigger turbo at the same pressure will move a lot more air than a small turbo. You want to run as much boost as you can, in the 20 to 30 psi range usually, rather than running just a tiny bit of boost. The turbo is a lot happier at higher boost. If you only wanted to run 12 pounds you should have bought a roots blower instead.
BoostedBowTie
Jan 3, 2020 06:46 PM
Rafe19
Oct 18, 2016 12:27 AM
bbowerman
Jul 26, 2015 10:57 PM
Jake75
Jul 22, 2015 09:20 PM
Cowboy17
Jul 9, 2015 08:22 PM
