4.8 turbo suggestions bws475 or precision
Old Jun 21, 2015 | 02:16 PM
Daniel-lsx's Avatar
Default 4.8 turbo suggestions bws475 or precision
Got all the turbo build parts just missing turbo,I'm looking for 700 hp I'm just still in doubt either a bw or a precision turbo any suggestions?and what site would be the best or any part # of turbos that had used that work well.thank you.
Old Jun 21, 2015 | 02:53 PM
oakley6575's Avatar
I like my S475. Spools pretty fast on my 4.8
Old Jun 21, 2015 | 02:56 PM
NemeSS's Avatar
Tc78 spools pretty quick on 4.8
Old Jun 21, 2015 | 03:23 PM
Daniel-lsx's Avatar
NemeSS the turbonetics tc78 would be the bb or journal? Who has the best deal I search it and it's listened for $999 and a t4
Old Jun 21, 2015 | 03:26 PM
Daniel-lsx's Avatar
Oakley6525 s475 which one Ur running and how much power it's makeong, you only running 1 walbro 450?
Old Jun 22, 2015 | 08:50 PM
TimDave217's Avatar
running a pt76 billet wheel and spool is so awesome with it! I made 727 on 19-20 ish pounds on a 4.8. The only thing i have against precision is that they are the only ones that can rebuild them when they need rebuilt or break. BW you could buy the parts and rebuild yourself or send it off to a cheaper company. Im all about that and that.
Old Jun 23, 2015 | 09:02 PM
Daniel-lsx's Avatar
I got a quote from Forced Inductions and they have the s475 with a 83mm turbine T4 for $849,would that be a good deal?or should I stick go for the tc78.
Old Jun 24, 2015 | 01:58 PM
TimDave217's Avatar
I say the bw is the way to go but either turbo will get you your goal. Bw may be a little bigger if that's a concern to you which it probably isn't if it's going on a truck.
Old Jun 24, 2015 | 03:31 PM
Daniel-lsx's Avatar
Yea that was my concern that it might of not fit,but yes it's going on a nnbs truck so I should be ok. Now my other question its going to be the fuel system.tim Dave what would be the best fuel pump And injector to run to support it
Old Jun 24, 2015 | 04:00 PM
Daniel-lsx's Avatar
Will the s475 with a 83mm turbine be good?
