View Poll Results: Which crank?
346 ci
33.33%
391 ci
16
66.67%
Voters: 24. You may not vote on this poll
346 or 392 with radix Poll!
What I am for sure going to run:
6.0L heads mildly ported
stock 6.098 rods with ARP bolts
2.75 pulley on the radix
3.905 bore, ok maybe 4.000 but we will see.
Unsure about either a stock 3.62 crank or a 4.100.
Basically 346ci or 393ci
About 12lbs boost or about 8lbs boost ~ give or take.
I think the more cubes with less boost will make more power anyways but will cost $800 more.
Basically 346ci or 391ci
less boost on more cubes=less heat=more power. I vote 391.
I guess you could look at it like this:
8 cylinders @ 12 pounds (each cylinder being 43.25)
9 cylinders @ 8 pounds (each cylinder being 43.44)
I say the bigger motor. For one you will be putting less strain on the motor and making the same or more power plus if you lator on decided to get say a turbo or turbos
you would have a good motor with a lot of torque. If you put the 4.100" stroke crank with the radix your going to have some awesome torque off the line
Are you going with an aluminum or a CI block?I don't think I would try to bore the 4.8 block to 3.905 and add a stroker crank.If you are going with a different block a LS2 block or a 6.0CI block with the 4.10 stroke would give like 412 CID or more depening on overbore.
I would say go with the 391ci. It would be nice bc it is would be the only one out there (that I know of). But how much can that Radix flow?? You just want to make sure that it doesnt besome restrictive.
