3 bar map questions
Old Dec 31, 2012 | 07:14 AM
slowec's Avatar
Default 3 bar map questions
Need to swap over to a 3 bar sensor . Must be a simple change out because there is not much info out there. Which one are you guys using and do you need to make any scale changes or is it plug it in and go?
THANKS!
Old Dec 31, 2012 | 09:21 AM
8 Second Club
You need to run a 3 bar os
Old Dec 31, 2012 | 09:29 AM
slowec's Avatar
UGGGG. Forgot that was part of the OS I am running to. trying to put the cart before the horse again!
Thanks!
Old Dec 31, 2012 | 09:38 AM
Gadgetized's Avatar
How much boost are you going to run? I am planning on going to a 2.5 bar.
Old Dec 31, 2012 | 09:53 AM
slowec's Avatar
Bout 19 right now.
Old Dec 31, 2012 | 10:07 AM
Gadgetized's Avatar
A 2.5 bar will get you up to about 22 psi plus it will work better for cruising.
Old Dec 31, 2012 | 10:12 AM
nonnieselman's Avatar
I think its already setup in the COS3..
Adjust the scaler and get to tuning?
Boost VE table goes to 275?
Old Dec 31, 2012 | 12:14 PM
slowec's Avatar
I am using cos 3
What scaler?
table goes to 275, but my 2 bap map maxes out at 198 kpa
Old Dec 31, 2012 | 01:08 PM
8 Second Club
OS and MAP sensor need to match.
Sounds like u r trying to run a 3 bar os and a 2 bar maf?
Old Dec 31, 2012 | 01:13 PM
8 Second Club
I have 12615136 as 2 bar on the truck
12223861 as 3 bar on the car
