3 bar map questions
Old Dec 31, 2012 | 01:15 PM
chevrolet all the way's Avatar
im in a 3 bar os in my dd truck too rodney. dont be skeered!
Old Dec 31, 2012 | 01:17 PM
8 Second Club
Regarding scaling: if the os matches the sensor type you are using, then you should be pretty close.
You can always tweak the scaler by comparing readings (with key on, motor off) between sensor and actual baro pressure. With key off, they should match
Old Dec 31, 2012 | 01:18 PM
8 Second Club
I meant: with key on, motor off, readings should match.
Old Dec 31, 2012 | 01:32 PM
nonnieselman's Avatar
Originally Posted by slowec
I am using cos 3
What scaler?
table goes to 275, but my 2 bap map maxes out at 198 kpa
Engine diagnostics>MAP> Sensor scaler
it stops at 198 cause thats where the 2 bar stops reading..
Text me this evening, ill get my laptop and get you some table numbers.
Originally Posted by AgFormula02
OS and MAP sensor need to match.
Sounds like u r trying to run a 3 bar os and a 2 bar maf?
I have 12615136 as 2 bar on the truck
12223861 as 3 bar on the car
Ive got him setup on a 12212156 OS with COS3 0202003
NO Maf at all.
Old Dec 31, 2012 | 02:22 PM
idahoblkss's Avatar
i got a 2.5 map s off a guy on tech that makes them. he sends data too for your tune. i would steer clear of 3 bar unless you absoloutly need it THE RESOLUTION IS HORRIBLE ! btw my 2.5 bar map has read up to 22.7 psi for me so far .
Old Jan 1, 2013 | 11:28 PM
foose04's Avatar
I'm liking this 2.5 talk, can you post up details on your talk source, part number for 2.5 sensor. Also, will I need to burn two credits on hptuners for this?
Old Jan 1, 2013 | 11:56 PM
smokeshow's Avatar
Mod with training wheels
DSteck on HPT forum makes them. There's another guy, his forum name is C5dude or something, he also makes them.
Old Jan 2, 2013 | 12:08 AM
Atomic's Avatar
I have a gauge for that
Even though the resolution is worse with a 3bar, unless you cam and tune are retarded, fuel requirements are fairly linear with manifold pressure. Basically, the lack of resolution is not an issue. This obvious does not apply on extreme setups, but I have yet to see one I would call extreme on this forum.
Old Jan 2, 2013 | 07:54 AM
Denali08's Avatar
Did anyone try the Dmax map sensor. I think it's 3.3 bar map.
BrandACDelco
Manufacturer Part Number213-4658
OEM Part Number12623671
I ordered one from Amazon.
Old Jan 2, 2013 | 09:14 AM
Im interested in a 2.5 bar or 3 bar setup as well but I don't think my VCm will allow anything but 2 bar. Is that correct?
