2014 going to speed density
Anyone help point me in the right direction for turning the truck over to speed density would I just need the same parts for the previous years. Any help would be appreciated. Thanks
You must use HPT. Efi live has virtual ve tables that aid in reproducing the ve coefficients. You can do SD on those years.
The beta versions of the software are very quirky... I had trouble downloading a tune from a PCM that had been tuned with the previous version. I'm sure they will work out the bugs quickly... but for the time being its definitely not ideal.
atleast with the 900 trucks there isnt a reason ive found yet for moddest setups to even consider SD...Im all for SD when needs to be but if you spec the right size tube a maf will be fine
its not like the 800 truck Mafs and Pcms where they were limited. The new slot style mafs work well. You extend the range by playing with tube size
