2014 going to speed density
Old Jan 16, 2015 | 01:27 PM
08DenaliT's Avatar
Default 2014 going to speed density
Anyone help point me in the right direction for turning the truck over to speed density would I just need the same parts for the previous years. Any help would be appreciated. Thanks
Old Jan 16, 2015 | 01:53 PM
Vortec350ss's Avatar
I haven't looked at the newer PCM's but I think you may be out of luck. I dont think it was possible with the 07-13 trucks as there was no VE table available to tune with.
Old Jan 16, 2015 | 02:32 PM
George C....'s Avatar
Formerly ScreamingL
The newer mafs support boost...keep the maf
Install it in a 4-4.5" tube and you'll have plenty of range
Old Jan 16, 2015 | 03:20 PM
This is very true. I should have been more careful in how i chose my words. I meant out of luck as in no speed density.
Old Jan 16, 2015 | 03:24 PM
BlackGMC's Avatar
Resident Retard
You must use HPT. Efi live has virtual ve tables that aid in reproducing the ve coefficients. You can do SD on those years.
Old Jan 16, 2015 | 03:30 PM
Ah... yup im HPT. figures.
Old Jan 16, 2015 | 03:31 PM
BlackGMC's Avatar
Resident Retard
I did see a post on FB where a new Beta version has the same option.
Old Jan 16, 2015 | 03:41 PM
The beta versions of the software are very quirky... I had trouble downloading a tune from a PCM that had been tuned with the previous version. I'm sure they will work out the bugs quickly... but for the time being its definitely not ideal.
Old Jan 16, 2015 | 04:35 PM
08DenaliT's Avatar
Ok so black you think I can on effilive?
Old Jan 16, 2015 | 05:17 PM
Formerly ScreamingL
atleast with the 900 trucks there isnt a reason ive found yet for moddest setups to even consider SD...Im all for SD when needs to be but if you spec the right size tube a maf will be fine
its not like the 800 truck Mafs and Pcms where they were limited. The new slot style mafs work well. You extend the range by playing with tube size
