2008 RCSB 4.8 turbo
Old Mar 5, 2015 | 07:03 PM
AlwaysOnKill's Avatar
Default 2008 RCSB 4.8 turbo
I've decided to go with a trick turbo kit with a 72 mm turbo and what I haven't figured out is what gear , stall , spark plugs and injectors to go with . I have a built 4l60e that I know I'll have to upgrade in the future but as of know I'll take it easy on it . From what I've read I have a fuel pump control module that controls my pump so I should be ok to 450whp . What spark plugs and gap do you recommend? The truck currently has a 3.23 gear with an open diff , so I ordered a true trac and can't decide on a gear . Which would be better 3.73 or 4.10 For a 4.8 ? And I have no clue on the stall 3200.. 3400 ? 60lbs injectors good enough ? I'd like to get y'all's feed back and see what others are doing to y'all's trucks ...
Ricky
Old Mar 5, 2015 | 07:20 PM
08lambochevy's Avatar
Id go 3.42 gears, 60 pound injectors are good, your stall is depending on what you plan on doing with the truck, Daily Driver? Track?
Old Mar 5, 2015 | 07:21 PM
And other people use different plugs and gaps, im using NGK BR7EF gaped at 0.28
Old Mar 5, 2015 | 10:11 PM
Track,I drive the truck less than 50 miles a week . I'd say it toy mostly. I used to daily a head cam 408 Tbss with 3400 stall with 100 shot . So stalls don't bother me. I just wasn't sure on gear and stall with small cube 4.8 with a turbo plus it being a pig.
Old Mar 6, 2015 | 09:25 AM
ZO6Ted's Avatar
Kind of depends on tire diameter. Many are a fan of 3.42s and such for a turbo to build load on it. I can only tell you my one experience on a different setup. 07 4wd 5.3, STS 67mm @ 5.5 lbs, built 4l60 Precision 10.5" 2800, 5050 race weight, 32" diameter 275/55/20's. 1/8 mi et stock: 10.39, After above mods: 9.54. I was pissed. It was a pig out of the hole. Only changed the 3.42's to 4.10's et 8.90 in same weather and no other changes. It drove like a different truck! Changed stall to 9 1/2" 3k precision and upped boost to 8.5 lbs, et 8.11 in ~ 100 degree temp. Went back in cold weather same setup et 7.64. It loved the 4.10's with such a big heavy tire.
Old Mar 6, 2015 | 10:31 AM
tim wellington's Avatar
Default gears
i have tried 342 373 and 410 .like my 410 the best .i think all trucks are 4000lb+
that a enough weight to keep turbo loaded
Old Mar 6, 2015 | 12:37 PM
oakley6575's Avatar
Put 4.10's or 4.56's in it. Don't fear the gear.
Old Mar 6, 2015 | 03:08 PM
I currently have 275/45/20 which is a 29.7 diameter tire .. Ill order a set of Bogarts like i had for my TBSS and run a 325/45/17 or 390/40/17 M@H Drag radial so thats 28.0 and 29.5 tires . Im thinking 3.73 or 4.10 as a gear option and 3.42 would be great if it was street only . What Rpm Stall did you have in the Z71 ?
Old Mar 6, 2015 | 06:20 PM
ZO6Ted's Avatar
I think your asking me...the 9 1/2" PI was rated 3k. It would flash to 28-3000 but I could stand on it a few seconds (don't recommend) and see 4400 @ full boost. There is a great automotive calculator at wallaceracing.com down the page on the left. It will help you decide based on expected trap speed. Gonna be fun!
Old Mar 7, 2015 | 08:12 AM
Beatdown Z's Avatar
Laid Back
I run 4.10's with a 29" tall slick and 3600 stall in my turbo 5.3 RCSB. Been 7.04 in the 1/8, with a 1.61 sixty and i'm still a total newb at launching a turbo setup.
