2006 Silverado Low boost .. Fuel pump Upgrade?
Old Dec 24, 2013 | 11:01 PM
Ws6ickness's Avatar
Default 2006 Silverado Low boost .. Fuel pump Upgrade?
Plan on running low boost no higher than 3-7 psi anytime soon. Im guessing the stocker cant keep up but since my truck is an 06 i have heard through the grapevine that it is a weird year for the pump setup. Do i need a fuel pump for this low of boost?
Anything on the 2006 that anyone knows about? Want to order me a pump pretty quickly so any help is appreciated. Unless the stock pump will suffice for low boost.
Thanks!!
Old Dec 25, 2013 | 12:02 AM
Boosted_Silverado's Avatar
i would never run a stock fuel pump being boosted, get a walbro 255.
Old Dec 25, 2013 | 12:21 AM
Ws6ickness's Avatar
Yes i thoughts so...... just need someone with some experience on the install on a 06
Old Dec 26, 2013 | 04:52 PM
Ws6ickness's Avatar
Bump for some info !
Old Dec 26, 2013 | 05:25 PM
bgray's Avatar
TOTM: June 2007
2006 gmc sieera 5.3, TVS 1900 running 9lbs of boost on stock pump. Never had an issue, Justin as blackbear said its golden. Its also my daily i pound the **** outta too
Old Dec 26, 2013 | 08:09 PM
Ws6ickness's Avatar
Dang man!!
Do you have a wideband guage?
Your probably the first person I've seen say the stock pump is fine lol
That's not a bad thing though!
Ever look at your AF ratio under full throttle ?
Old Dec 26, 2013 | 08:14 PM
Ws6ickness's Avatar
Also what injectors are you running ?
Thanks
Old Dec 27, 2013 | 08:34 AM
Ws6ickness's Avatar
Anyone ?
Old Dec 27, 2013 | 10:10 AM
Atomic's Avatar
I have a gauge for that
The flexfuel pump is a little bigger than the stock one, but I would still upgrade to a walbro400 or 450.
Old Dec 27, 2013 | 10:16 AM
tempoffroad's Avatar
I just replaced my 255 for a 450. If I were you I would just skip the 255 for the 400 or 450 like Atomic said. Its only a few more dollars and pushed enough fuel for my single.
