2002 2500hd tvs 1900 install.
Old Dec 26, 2017 | 10:55 AM
02SubZ71's Avatar
Since this is an 02, how did you handle the throttle cable arrangement? Been trying to figure out the easiest way to get this done on mine. Also, how do you like it?
Old Dec 26, 2017 | 11:36 AM
M60gov20's Avatar
I just bent a 90 in a piece of metal I had. Bolted it to the top t-body bolt. I rounded the edge so it would lock into the t body housing. Then I flipped the oem bracket and turned it around backwards and bolted it to the bracket. It was really easy and just took a few minutes to do.
I liked it ok, but it got a lot better with a 3" pulley. The bottom end is great, Only I'm needing more fuel now. I have an 8 rib 2.7" pulley, bigger injectors and a walbro 450 for it now. Need to get the rest of my 8 rib set up and a 92mm tbody, then she should be a lot more fun!
