2000 sierra 4.8 build advice?
Old Oct 19, 2012 | 10:49 PM
loganlewis's Avatar
an nv3500 is only rated at 300ft lbs. I would swap to something different as well
Old Oct 19, 2012 | 11:52 PM
SLCviaAK's Avatar
From what I've gathered, LS9 gaskets, head studs, cam, pushrods, valve springs, rocker trunion upgrade, NNBS/TBSS intake, 90mm tb, KB or trick hot pipes, BW turbo, meth inj, 4L80E, true trac, gears, mild stall, injectors (bigger than you think you need), BIG pump or duals, and SPOT ON TUNING . . . that will get you more than enough.
I forget anything? Please, experienced pros correct me if I am wrong/missed anything.
Old Oct 20, 2012 | 05:13 PM
murdock.dean's Avatar
If anyone build a front mount turbo hot side piping please let me know, thanks
Old Oct 22, 2012 | 05:42 PM
Do the LS9 head gasket just go right in or do they have to be modified?
Old Oct 22, 2012 | 07:01 PM
kbracing96's Avatar
I've build 100 or so sets of hot pipes!
They just bolt right in, got them in my truck
Old Oct 22, 2012 | 10:26 PM
SLCviaAK's Avatar
Talk to this guy ^^^^^^
Old Oct 24, 2012 | 05:55 AM
slowec's Avatar
KBRACING96 -still loving my kit EVERYDAY on the way to work. BOOST is GOOD
ARC
57
Feb 21, 2022 10:54 AM
USMCvet0311
Aug 14, 2015 10:28 PM
Suburban2500
Jul 19, 2015 04:50 PM
4B11T
Jul 13, 2015 03:48 PM
ALynch
Jul 6, 2015 09:49 AM
