2 Step install
Old Sep 14, 2013 | 04:30 AM
mongooseboy000's Avatar
Default 2 Step install
Just bought the MSD 8733 for the truck. how are you guys wiring it as we have autos? are u using a push button switch or what? attempting to install tomorrow
Old Sep 14, 2013 | 05:18 AM
foose04's Avatar
Race Truck!
Yeah man, just a momentary switch you can pickup at napa. Just run it to a ground and your good to go.
Old Sep 14, 2013 | 10:28 AM
idahoblkss's Avatar
How does the 2step work if say you want to set it at 3600 rpm's and your stall will only foot brake to 3000 rpms? Or will it only set at rpm's below your stall speed?
Old Sep 14, 2013 | 10:32 AM
kbracing96's Avatar
When I had one on my truck, I just taped into the brake light switch so when even I stepped on the brakes, it was active.
Old Sep 14, 2013 | 10:46 AM
black00chev's Avatar
Slowest turbo build ever!
I like Kyle's idea. How well did that work when brake boosting?
Old Sep 14, 2013 | 10:58 AM
kbracing96's Avatar
It worked great! Only time your on the gas and brake at the same time is when your brake boosting.
Old Sep 14, 2013 | 11:04 AM
Originally Posted by foose04
Race Truck!
thanks man i will go to napa and pick one up.
no more foot stand burnouts lol. but this is a solid idea.
Old Sep 14, 2013 | 11:07 AM
2doorfury's Avatar
Do you have a pic of ur set up kyle? That exactly what I was thinking of doing. Or maybe explain how to do it in detail?
Old Sep 14, 2013 | 11:15 AM
kbracing96's Avatar
No pic. They are setup to be turned on with either a hot wire or a ground, so I found a wire that was hot when you stepped on the brake and taped into that. You could always put an interrupt switch inline if you wanted to do brake stands, but my truck will just do rollin burnouts!
