2 Step install
Old Sep 14, 2013 | 11:18 AM
idahoblkss's Avatar
Originally Posted by idahoblkss
How does the 2step work if say you want to set it at 3600 rpm's and your stall will only foot brake to 3000 rpms? Or will it only set at rpm's below your stall speed?
Can anybody answer this?
Old Sep 14, 2013 | 11:39 AM
Atomic's Avatar
I have a gauge for that
It will just never cut timing...its a secondary rpm limit, you wont notice its doing anything unless you get to its set speed.
Old Sep 14, 2013 | 01:46 PM
oakley6575's Avatar
Yea you have to set it a couple hundred rpms less than what you can hold the converter at or you will just push through the verter before hitting the 2 step.
OP, I just installed the same 2 step last week and it took 10 min. Easiest install i've done on my truck and fun to use
Old Sep 14, 2013 | 02:13 PM
Mangled03gmc's Avatar
Baltimore Whore
I run mine using the brake as the momentary switch. Have a regular toggle to arm it. Works well.
Old Sep 14, 2013 | 02:30 PM
Baltimore Whore
https://www.youtube.com/watch?v=JYLe...Ik660M3iqRBRhg
Old Sep 14, 2013 | 05:12 PM
Choda's Avatar
Perfect vid. Thanks
Old Sep 15, 2013 | 07:11 PM
Tuckin15s's Avatar
Mangled03gmc That's exactly how I wanna do mine. Thanks for the video!
Old Sep 15, 2013 | 09:25 PM
Baltimore Whore
Originally Posted by Choda
Perfect vid. Thanks
No prob guys. I just like to mess with people at red lights haha
Old Sep 16, 2013 | 10:51 AM
Gadgetized's Avatar
I have mine on the brake switch too. I have the interrupt switch so it isnt always working. So I can do brake stands, then 2 step at the track. I am actually using the 2 step built in to the EFI Live COS. It works real well.
I might get the MSD someday as I am not too fond of cutting fuel instead of spark.
Old Sep 16, 2013 | 11:07 AM
mongooseboy000's Avatar
thanks for all the help i got it installed. used a pushbutton switch as a temporary ground. will post vids soon
