2 step?
Old Oct 14, 2008 | 09:08 PM
  #21
nonnieselman's Avatar
I went through my dang truck, put new booster, master cylinder, check valve, SS lines, rotors, pads and i still couldnt get mine to stall up without pushing "Thru" the front brakes. I prolly wasted a gallon of brake fluid tryin to bleed the lines.
Went to the junkyard and picked up a hydroboost setup off a newer Tahoe. Best $160 ive ever spent!! Not to mention it was half of what all the new Vacuum booster and stuff was.
Now i can brake stall it up with my toyos on a back country road with no problem and get 4psi..
At the track i can get 5psi off the line with my DRs.. RPMs are at 2500 or so with the stock 80E converter.
And the brakes work a whole lot better when towing and stuff!!
So if i were to do it again, id go Hydroboost..
Old Oct 14, 2008 | 09:44 PM
  #22
2ktransam's Avatar
I don't have a problem with pushing through the brakes until about 8psi. When the turbo is cold I can hold it against the converter for as long as I want without pushing throught the brakes but it won't make boost at all.
Old Oct 14, 2008 | 09:46 PM
  #23
1989k1500's Avatar
Originally Posted by 2ktransam
Wilde, Does your truck stink without the cats? I just put cats back on my TA after four years because I couldn't stand to drive it.
I cant smell anything in mine, unless theres race gas in it.
Old Oct 14, 2008 | 09:57 PM
  #24
I love the smell of race gas!!!!!
SS94S10
Jan 3, 2019 01:57 PM
zblee
Nov 11, 2015 12:41 AM
wretched73
Oct 28, 2015 09:21 PM
elir_mn
Sep 19, 2015 11:43 AM
whippledstepside
Sep 17, 2015 05:02 AM
