2 step?
Old Oct 13, 2008 | 10:36 PM
2ktransam's Avatar
Default 2 step?
Anybody using a 2 step on their turbo truck? Can you use a 2 step with cats? I need to find a way to heat my turbo at the track easier without having to do a burnout and wasting my tires.
Old Oct 13, 2008 | 10:41 PM
2toneblown's Avatar
Why would you need to heat your turbo????
Old Oct 13, 2008 | 10:45 PM
2ktransam's Avatar
The biggest down fall of the STS is the turbo and pipes cooling down in between runs at the track. When the turbo is cold you can't build boost off of the line.
Old Oct 14, 2008 | 08:06 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
are you doing the syty shuffle? I never had trouble building boost.
Then again, my engine stayed cooler if I idled in the staging lanes down in florida...
Old Oct 14, 2008 | 08:12 AM
quicksilverado's Avatar
Are you running slicks at the track? If so, you need to heat them up for traction. If you are using street tires at the track a 2-step will not help. You will have a big smoke show off the line.
Old Oct 14, 2008 | 08:28 AM
silver-mod-o's Avatar
Hunt&Fisherator
I agree with quicksilvy, get a set of slicks AND a 2 step....
Old Oct 14, 2008 | 08:36 AM
Wilde Racing's Avatar
How do I change this text
Is the truck 4 wheel drive? I found that is I begain to brake stall around 1200 rpm a few runs before mine, it would heat the exhaust enough to build boost at the light...
Old Oct 14, 2008 | 10:02 AM
Hawk179's Avatar
We make a Two step if you are looking for one.
R
Old Oct 14, 2008 | 11:06 AM
1989k1500's Avatar
How much Rick?
Old Oct 14, 2008 | 11:09 AM
Hawk179's Avatar
Originally Posted by 1989k1500
How much Rick?
They start at 325 for the standard optioned unit.
R
