2.8 vs 2.75 Radix pulley
Old Jun 12, 2006 | 10:43 AM
thunder550's Avatar
High on diesel fumes
Default 2.8 vs 2.75 Radix pulley
Will I notice any difference at all between these two pulleys? I tried to get a 2.75 from Nelson but he's out and is not re-ordering, and the smallest that Magnuson sells is a 2.8. I found a couple other places that have 2.75's but they are expensive.
Old Jun 12, 2006 | 10:47 AM
jephs422's Avatar
I would think it would be good for just under a 1/4 pound of boost. Maybe 4hp at best.
Old Jun 12, 2006 | 10:54 AM
BlownChevy's Avatar
blownerator
25 Year Member
If you were going to a 2.75 from the 3.1 I would say do it, but since you have the 2.8 on there I would not waste the time or money.
Old Jun 12, 2006 | 10:59 AM
dewmanshu's Avatar
Moderately Differentiated
WHat do you have? The 3" right? I was gonna get the 2.75 as well, but he was out. I guess I'll settle for the 2.8, what's .05" in boost terms? Which brings up another question, if you were to go from the 3" to 2.8" what kinda of boost gain is that?
Old Jun 12, 2006 | 11:00 AM
thunder550's Avatar
Yep I have a 3", I am looking at getting either a 2.8 or a 2.75. Looks like it won't make much difference in boost - I think I'll just get the 2.8 from Magnuson. Unless someone knows where I can get a 2.75 for a reasonable price (i.e. around $75 or less...)
Old Jun 12, 2006 | 11:02 AM
krambo's Avatar
I have swapped the pulley (2.75) to the 2.8 on the dyno and picked up nothing (no additional tuning). I chose to use the 2.8 just to help with the heat build-up.
I also swapped out the 2.8 for the 3.0 on the dyno and was able to add a little bit of timing to the 3.0 but the 2.8 had ~5RWHP more than the 3.0 with the added timing.
As BlownChevy stated, once you are under the 3.0 there isn't a ton to be gained,...at least on my application. Stick with the 2.8
BTW, I run the 2.8 all the time.
Old Jun 12, 2006 | 11:04 AM
thunder550's Avatar
What was the boost loss going from the 2.8 to the 3.0?
Old Jun 12, 2006 | 11:10 AM
Mr. Sandog's Avatar
Pulley Boys has the 2.75" pulleys.
Old Jun 12, 2006 | 11:16 AM
dewmanshu's Avatar
95 bucks.
Old Jun 12, 2006 | 11:36 AM
dewmanshu's Avatar
How much from magnuson? 75 bucks?
