2.8 Magnacharger pulley on a 6.0?
Old Jan 29, 2008 | 11:46 PM
smcdonn's Avatar
Default 2.8 Magnacharger pulley on a 6.0?
Has anyone put the 2.8 magnacharger pulley on the 6.0? I figure it really needs to be reprogrammed but was wondering if anyone has got away with this without retuning.
Old Jan 30, 2008 | 09:24 AM
Last Call's Avatar
TOTM: January 2007
I doubt anyone has.. That 2.8 is going to generate a lot more heat than a 3.0 or 3.1 pulley and create some KR. You will also be getting into boost a lot sooner and need a tune to compensate for that.
Old Jan 30, 2008 | 09:41 AM
krambo's Avatar
I run the 2.8 on my LQ9. You will need some changes in the tune to run it safely and as everyone knows, your IAT's will be higher so you will need to compensate for this in the summer (less spark advance mainly).
Old Jan 30, 2008 | 02:49 PM
old motorhead's Avatar
Had one on mine. It was good for 8 more hp and 20# torque vs the 3" pulley. I took it off. Boost comes in much quicker, but I thought there wasn't enough of a power increase to warrant spinning the radix that fast. I'll put it back on if I go to the track. If I remember right, tune was changed a little on the 6.0 with 2.8" pulley vs the 5.3L with the 3.0" pulley. Not much difference in total boost on the 6.0 with the pulley swap. The boost just comes in quicker
Old Jan 30, 2008 | 03:43 PM
zippy's Avatar
You'll need to have it programmed for sure. What year is your truck? If you have an 04' or newer you might have to up the injector size.
Old Jan 30, 2008 | 05:55 PM
terravast4's Avatar
I went up to an 2. 85 from a 3.2 on my 05' 5.3 and gained about 25 rwhp and about 46 rwtq kept the same injectors and got a tune. boost does come in a lot earlier though. Still getting used to it as I did a trans, 3000 stall and a pulley change all at the same time so it just felt weird for a while.
Vortec350ss
Jan 12, 2016 10:36 PM
Avalanche2002
Nov 30, 2015 07:31 AM
turbo6c3
Oct 5, 2015 06:11 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
