2.5 bar map anyone?
Old May 22, 2013 | 11:53 PM
smokeshow's Avatar
Mod with training wheels
Originally Posted by foose04
Tell me more!
Buy 3 bar zr1, harness, cut and solder.. Is it not the same size as the stock one? Why did you relocate?
What was done in the tune? With this work on a 04 and Hptuners?
Thanks for the info sir!
That sensor doesn't work on our trucks because you can't input the negative offset value for the calibration. Otherwise I would have used the 2.5bar sensor I have. That's why mine is for sale
Old May 23, 2013 | 11:40 AM
idahoblkss's Avatar
em i missing something here, why are some of you running 2.5 and 3 bar sensors at boost levels that a 2 bar will pick up? i think my 2 bar read up to around 17psi just fine and my 2.5 got me to 22.7 ish psi.
Old May 23, 2013 | 08:37 PM
blue0453's Avatar
I was given my 3bar by a friend so figured go ahead. Have plenty of room for growth.
Old May 28, 2013 | 01:14 AM
foose04's Avatar
Well I need a 3 bar lol. My HPtuners shows I can upgrade to a 3 bar tune, so what am I missing that says it won't work? That upgrade, zr1 sensor and pigtail won't work?
Old May 28, 2013 | 01:23 AM
oakley6575's Avatar
Didn't smokeshow say the zr1 map doesn't work because our PCM's won't allow a negative offset. Only the newer pcms can handle that maps calibration.
Old May 28, 2013 | 08:11 AM
GONEB4U's Avatar
10 Second Club
Are you guys using the ZR1 map sensors for speed density tunes? Or are you using it in conjunction with the mass air? At what psi are you guys upgrading from the stock one cause my tuner never told me that I need to change the map on my 7-10psi turbo NNBS truck on a mass air tune.
Old May 28, 2013 | 12:08 PM
Gadgetized's Avatar
1 bar is atmospheric pressure. About 14.5 PSI. A 2 bar sensor will read atmospheric pressure and 1 more bar, so about 14.5 PSI of boost. A 2.5 bar will read atmospheric pressure and 1.5 more bar, so about 21.75 PSI of boost. A 3 bar will read atmospheric pressure and 2 more bar, so about 29 PSI of boost. You shouldnt run your boost right on the peak of your sensor in case you overboost, or it would lean your engine out. I was thinking of going with a 2.5 bar, but might go higher.
Old May 28, 2013 | 09:00 PM
blue0453's Avatar
Zr1 sensor and pigtail rob. Im not a tuner but my truck runs and drives fine with it.
Old May 28, 2013 | 09:40 PM
smokeshow's Avatar
I've got a ZR1 sensor and connector if anyone wants to try it lol... But even my 3 bar sensor now doesn't show the most accurate information, and its actually meant for our stuff.
Old Jun 30, 2013 | 10:29 PM
2ktransam's Avatar
I'm running a 2.5 bar sensor and it works good. There is a guy on ls1tech that makes them out of stock sensors so they are a direct swap. I have ran up to 19psi and it worked great. I'm using efi live to tune it.
