2.3 Whipple 608RWHP/672RWTQ.
Very nice numbers on a Mustang Dyno for a cam only LQ9 with only 13lbs from a 2.3L. Says a lot for that BTR cam. Gives me a lot of hope for the cam going in my build considering they have very similar specs and valve event timing. Just curious, what is your pulley ratio, ie how fast are you spinning the Whipple?
I look forward to seeing your results as well. I will be using TEA/TFS 245's on mine so they probably flow close to your ported LS3's on the intake side. Nice to see the twin-screw builds popping up on here recently.
8.29/2.75 = 3.01. Max blower speed per Whipple is 18000 RPM so anything over 6K engine RPM....
