15 Degrees Outside and Turbo Smoked
I left the house this morning and about a mile away my truck started smoking. It got to the point of being embarrassing.
I pulled into a store to get a coffee figuring I was going to limp back home. When I pulled out it didn't smoke as bad then cleared up, completely.
I smelled the smoke, it was oil (pretty blue) and it was coming out the exhaust.
I pulled out as soon as it started, no warm up.
It was 15 degrees out.
The only thing I can figure is:
The oil pressure was high due to being cold and with that, the restrictions around the turbo bearings (that keep the pressure up before the drain) combined to push some oil out past the seal.
After things warmed up it went back to normal.
If it was a failure it wouldn't have cleared up.
Has anyone had this happen???
Oil is 5W-40 synthetic changed every 7K.
Turbo has about 25K on it.
KB Racing kit
KB Racing kit
My F350 work truck does the same thing all the time. Its a matter of the turbo seals not being warm enough and letting a little oil into the turbine. Just have to try and stay out of any decent boost until its warmed up enough.
KB Racing kit
KB Racing kit
I agree with the others about your maint schedule.
