112,122,tvs iats
Old Apr 18, 2009 | 02:48 PM
PSM's Avatar
PSM
Default 112,122,tvs iats
The IAT's are very manageable with my current set up, but I want (need) more power. I'm at about 7psi now at wot, 6psi under heavy part throttle. I was going to pulley down to the 2.8 pulley but am worried about higher iats. Would the 122 pullied to give me the same boost as the 112 with a 2.8 (guessing 9-10 lbs) gain me that much of an iat advantage? Or should I not even bother and just go strait for the tvs? Also I thought I would avoid belt slip by going to the bigger blower with a bigger pulley.
The other factoid is that I rarely go wot, but rather use heavy, quick pokes of the throttle of 70% (hense the partial 6psi number above) up to maybe 4500-5000 rpm, then just go back to normal driving. I wonder if that would keep iats much lower on the older 112/12w if i pulley down?
This winter when it was below 0deg outside, A wot run got me to 7-8 psi in part throttle and my normal 6psi part throttle has never felt the same since.
Old Apr 18, 2009 | 04:42 PM
XLR8NSS's Avatar
Adkoonerstrator
Why don't you pulley down your current setup first and see how it is. I think you will like it with a few more psi! IATs will be higher of course but, check it out.
IATs are just a non issue with the TVS IMHO but, it's a lot cheaper to buy a pulley rather than a whole new blower.
Old Apr 18, 2009 | 05:07 PM
03tahoe22's Avatar
Im at 11psi and Ill never go back to 6psi..... I have 160* iat temp that will just have to be dealt with....Pulley down!
Old Apr 19, 2009 | 12:55 AM
PSM's Avatar
PSM
Thats too easy!
moregrip
Jul 26, 2016 11:21 AM
Mr. Chainsaw
Oct 18, 2015 08:00 PM
JordanH
Oct 3, 2015 03:59 PM
Jake75
Oct 2, 2015 02:28 PM
old motorhead
Sep 29, 2015 08:22 PM
