112,122,tvs iats
The IAT's are very manageable with my current set up, but I want (need) more power. I'm at about 7psi now at wot, 6psi under heavy part throttle. I was going to pulley down to the 2.8 pulley but am worried about higher iats. Would the 122 pullied to give me the same boost as the 112 with a 2.8 (guessing 9-10 lbs) gain me that much of an iat advantage? Or should I not even bother and just go strait for the tvs? Also I thought I would avoid belt slip by going to the bigger blower with a bigger pulley.
The other factoid is that I rarely go wot, but rather use heavy, quick pokes of the throttle of 70% (hense the partial 6psi number above) up to maybe 4500-5000 rpm, then just go back to normal driving. I wonder if that would keep iats much lower on the older 112/12w if i pulley down?
This winter when it was below 0deg outside, A wot run got me to 7-8 psi in part throttle and my normal 6psi part throttle has never felt the same since.
Adkoonerstrator
Why don't you pulley down your current setup first and see how it is. I think you will like it with a few more psi!
IATs will be higher of course but, check it out.
IATs are just a non issue with the TVS IMHO but, it's a lot cheaper to buy a pulley rather than a whole new blower.
IATs will be higher of course but, check it out. IATs are just a non issue with the TVS IMHO but, it's a lot cheaper to buy a pulley rather than a whole new blower.
Thats too easy!
