112 and 122 pulleys interchangable? & what belt size?
Old May 4, 2009 | 11:06 PM
SimpleManLance's Avatar
Default 112 and 122 pulleys interchangable? & what belt size?
are 112 pulleys the same pulleys that are ran on the 122? i have a 112 3.2 pulley and want to make sure it will work on my 122 before i go though the hastle.
also does anyone know the belt size for a 3.2 pulley?
Old May 5, 2009 | 12:38 AM
JaymzSS's Avatar
Pulley size -Belt Size -Boost psi.(apx.) - Goodyear# - Gates#
2.75" Pulley = 111.0 " Belt = 9 to 10 psi. - P/N=4061110 - P/N=K061110
2.8" Pulley = 111.0 " Belt = 8.5 to 9 psi - P/N=4061110 - P/N=K061110
2.9" Pulley = 111.5 " Belt = 7.5 to 8 psi. - P/N=4061115 - P/N=K061115
3.0" Pulley = 111.5 " Belt = 7.0-7.5 psi. - P/N=4061115 - P/N=K061115
3.1" Pulley = 112.0 " Belt = ---6--- psi. - P/N=4061120 - P/N=K061120
3.3" Pulley = 112.0 " Belt = 5 to 6.5 psi. - P/N = 4061120 - P/N=K061120
Old May 5, 2009 | 11:24 AM
TX Tahoe Z71's Avatar
Those boost numbers seem low. What are the boost numbers for? A 112 or 122, 6.0 or 5.3, long tubes or stock manifolds?
Old May 5, 2009 | 02:58 PM
mike mcginnis's Avatar
11 Second Club
depends on if you have jackshaft, and if the rear is over driven or underdriven. the belt size thing should eb right but im speaking of psi
Old May 5, 2009 | 03:26 PM
I believe the 112 and 122 are both nose drive for gm truck/suv applications (save SSR & H3)
Old May 5, 2009 | 03:59 PM
SuperchargedSS's Avatar
i don't think they are the same pulleys? 112 vs 122, not sure tho.
Old May 5, 2009 | 07:34 PM
anyone else know if they are interchangeable?
Old May 5, 2009 | 10:50 PM
BlownChevy's Avatar
blownerator
25 Year Member
yes...
Old May 5, 2009 | 11:24 PM
zippy's Avatar
Those numbers are for a 6.0L with an MP112.
Old May 5, 2009 | 11:26 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by BlownChevy
yes...
