11 Silverado TVS 1900, low on boost
Old 10-19-2016, 02:18 PM
69CapriceHDTP's Avatar
Heres another log. I did get a 2bar map sensor on the way as well. I will get the A/F gauge hooked up in the next couple nights as well. How is it that I can wire that so I can have that on the datalog as well? I am new to hptuners so I may need a lil help. Thanks!
File Type: hpl
Old 10-20-2016, 11:38 PM
I have a gauge for that
Atomic's Avatar
I just sent you a PM, I will get you taken care of
Old 10-21-2016, 06:39 AM
madmann26's Avatar
True!!!
Old 12-12-2018, 10:39 AM
GoatChs's Avatar
Resuscitating this thread for benefit of the "troubleshooting" info. Install instructions are always "go right" and don't really help when you come across these types of issues and, being a guy that buys his share of previously owned equipment, these "work throughs" are very helpful. The OP stated that the tune was done by a reputable tuner (not some shady joker), but FFDP and Atomic indicated that the logs have several segments that hadn't been touched that should have been. Atomic also mentioned a possible bypass valve issue.
Did you find this to be strictly an incomplete tuning issue or was there a hardware problem?
Old 12-13-2018, 03:13 AM
Mod with training wheels
smokeshow's Avatar
Fairly certain this was the issue, but no response from that guy.
https://www.performancetrucks.net/forums/forced-induction-159/tvs1900-cruising-issue-547084/page3/#post5393875
Old 12-13-2018, 10:08 AM
First thing I noticed was the map sensor setting if you changed the map you need to up those numbers to match the sensor or it will not read right.
Old 12-14-2018, 09:11 PM
GoatChs's Avatar
Ahh...yeah, that other thread spells it out pretty well. on a related note, I had a "tuner" like that once...back in 2004, I was his first GTO. A fairly simple H/C & headers...I was barely able to make it to my current tuner's shop without a meltdown (so lean above 2k it had the headers glowing). Apparently the GTO has a different segment structure than the f-body/vette/truck tunes that everyone was accustomed to...or so it was explained.
Thanks for the reply.
Schiavonske1013
08-15-2016 11:09 AM
jbaum02
08-14-2016 09:08 AM
2FNQUIK
08-04-2016 10:29 PM
OldPainless
07-30-2016 10:18 AM
Quick Reply: 11 Silverado TVS 1900, low on boost
