11.9 ET Magnacharger Questions...
Old Jun 13, 2009 | 09:50 PM
Pro Stock John's Avatar
Registered User
Default 11.9 ET Magnacharger Questions...
I have some questions about the Magnacharger/Magnuson/Radix superchargers.
I've got a car that is maybe around 4200 raceweight, and I'm piecing together a 5.3 with 317's, rebuild 4L80E, maybe a 3600 stall, and not sure on rear gear let's assume 3.73's right on 28" tires.
I'm wondering if the MP112 can be pulleyed up to get this combo on paper to run 11.9's? I might consider Vortech or Procharger kits too, I'm a bit open but the strong midrange of the Magnachargers would help this 'sled' get going.
The car will look like this in about a month:
Old Jun 13, 2009 | 10:54 PM
sixltrbtr's Avatar
3600 stall might be a little to big with the magnacharger. You might be skipping some good power at lower rpm's. Good looking car!
Old Jun 13, 2009 | 11:37 PM
silver-mod-o's Avatar
Hunt&Fisherator
Ideally I'd think a TVS1900 and a 3000 converter, but I think the 112 would be close for sure.
Old Jun 14, 2009 | 01:16 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
I'd think you could get it closer to 11.3's.
Old Jun 14, 2009 | 01:52 AM
BLOWN 364's Avatar
Had a converter that flashed at 3600-3800 & it was awful on the street with the radix, plus 9 MPG Replaced it for a very tight 3000 stall for the horsepower. MPG went up to 16 around town & the toque felt like it doubled to the ground.
It will be tough to get there with a 112, but can be done with race gas/meth. IMO go TVS1900 & you will secure high 11's much easier without a doubt just depends on if your trying to get there on straight pump gas. There would no problem on race gas or with meth injection getting mid to low 11's with a TVS1900.
Old Jun 14, 2009 | 04:51 AM
stock48's Avatar
9 Second Truck Club
I think the 112 might hit mid to high 11's at 4200LBS but I would't run those 317's, go with cut 243's or cnc'd 5.3 heads. CR needs to stay near 9.5:1.
Old Jun 14, 2009 | 07:14 AM
KySilverado's Avatar
I think the 112 would get you to your goals easily with the right combo. Especially at 4300lb, and of course traction. I'd shoot for about 10psi, which the 112 can do fairly easy on the 5.3. Probably a 3.0 or 2.9 pulley. I also agree with the other guys. A smaller converter than you mention, small boost specific cam and good exhaust. Keep the compression in the 9.5 to 10.0 range.
Old Jun 14, 2009 | 09:05 AM
TrickTurbo's Avatar
Truck Sponsor
I like that body style. If you donot get the et you want put nitrous on it. That'll fix it. LOL
Old Jun 14, 2009 | 09:52 AM
quicksilverado's Avatar
How many trucks with the 112 have gone into the 11s?
Old Jun 14, 2009 | 10:36 AM
BLOWN 364's Avatar
I have, but not very many have boost only. My last passes with the radix were 1/8 mile boost only 7.3's @ 96 beating the hell out of the tune with timing, meth inj. & race gas shifting @ 6600 which converts over to around 11.50's @ 119 in the 1/4.
Plus not to mention that was on a GT2-3 cammed 6.0.
