10psi on a 6.0L???
Old Oct 6, 2008 | 09:44 PM
  #21
Originally Posted by zippy
If you plan to tow with that make sure to put an EGT sensor in there. That is the main issue to worry about when towing. If you're running a 2 bar you can tune it for all boost levels for the most part. Run a nice boost controller and just back the peak boost down to 6psi or so when towing.
XLR8NSS, are you still using the VVT and the VVT timing table? That could cause some knock issue's at part throttle for you. Just a thought.
i run a EGT, boost, and wide band gauges
Old Oct 6, 2008 | 10:00 PM
  #22
bud8fan's Avatar
my just changed to a bigger turbo and 80e from a 65e but had the t70 in there and dynoed 550 hp with the t70 and everything else in my sig is about the same as yours on 9 psi...
Old Oct 6, 2008 | 11:09 PM
  #23
Blowndenalixl's Avatar
Not sure if this is useful or not but have been towing a 6500 lb travel trailer during the summers with my Maggied Denali for 4 years now (longest trip approx 500 miles in 100 degree heat). Max boost I achieve is 5 lbs (3.1 inch pulley). EGT at times up to 1600 when cranking it up a hill but most of time in 1200 to 1400 range cruising at 60mph or so.
So I think if keep boost under 6 as recommended when towing should be good to go.
Good luck. By the way, what are you 0-60 and 1/4 mile times with that turbo setup?
D
p.s. also have a 2 bar tune.
Old Oct 6, 2008 | 11:52 PM
  #24
2ktransam's Avatar
I have been running 10psi on my LQ4 for about three days now.LOL So far I am at 16.5 degrees of timing and no knock but I am spraying 2 625cc meth nozzles. I did a 8psi launch tonight and had the truck sideways in 4wd. Hopefully I will get it to the track soon. Good luck with your tune.
Old Oct 7, 2008 | 02:12 PM
  #25
XLR8NSS's Avatar
Adkoonerstrator
VVT timing tables are zeroed out completely for now. The "island" in the table for cruising causes problems with the bypass valve operation because of high MAP. I might try retarding the cam some as rpm rises like the stock table does now that my tune is dialed in pretty good.
Old Oct 7, 2008 | 10:47 PM
  #26
So I Think 8psi Will Be The Tune Until Meth, I Guess We Will See, I Was Hoping It Could Be Done At 10psi
calsdad
Jun 14, 2023 11:07 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
old motorhead
Sep 29, 2015 08:22 PM
Forcefed81
Sep 8, 2015 10:02 PM
