10psi on a 6.0L???
Old Oct 6, 2008 | 09:15 PM
Stoichiometric's Avatar
Overlap will actual make matters worse when the exhaust pressure overcomes the intake pressure and pre-heats the charge air. Just keep the timing conservative and maybe even run less boost when towing if you ever hear it detonate.
Originally Posted by lafnlt1
we have tried to tune it before on a stk cam at 10psi with no luck, knock really bad but i did have a couple things wrong at the time like forgetting to more the iat sensor and i was still running a maf
dont know if the cam would help bleed off some cylinder pressure
ive had the truck at 8psi so far with no problems but want to see if it will make more!!
Old Oct 6, 2008 | 09:16 PM
good point, so far its looking like it is staying at 8psi so far
Old Oct 6, 2008 | 09:19 PM
parish8's Avatar
single digit dreamer
get a meth kit and you are good for 11-12psi. maybe more if you really spray a lot.
for an all out effort meth is just a pain in the *** but for a street truck that only runs pump gas it is a great way to give you a few extra psi. a few psi can easily be 100hp
Old Oct 6, 2008 | 09:22 PM
+1
With one walbro intank pump!
Old Oct 6, 2008 | 09:25 PM
+1
meth is the next thing unless i just do a short block first, spend $500-600 on a meth setup or yank the motor and build a low compression short block for $1500-2000
Old Oct 6, 2008 | 09:29 PM
WJ MARK's Avatar
i run between 10-12 psi with meth and no issues. this is on a 5.3
7845's Avatar
Banned
meth is still nice to have!
Old Oct 6, 2008 | 09:33 PM
XLR8NSS's Avatar
Adkoonerstrator
I'm running ~9psi(intercooled) on my 6.0L (9.6:1 cr) and had to remove quite a bit of timing in the midrange to get rid of the knock. Total timing is 14 degrees.
I don't have experience with boost higher than that on a stock engine but, seems like you'd have to remove even more timing and it might start to get to a point of diminishing returns.
Old Oct 6, 2008 | 09:37 PM
zippy's Avatar
If you plan to tow with that make sure to put an EGT sensor in there. That is the main issue to worry about when towing. If you're running a 2 bar you can tune it for all boost levels for the most part. Run a nice boost controller and just back the peak boost down to 6psi or so when towing.
XLR8NSS, are you still using the VVT and the VVT timing table? That could cause some knock issue's at part throttle for you. Just a thought.
