102mm TB with x-link - Any have setup working?
Old Apr 20, 2020 | 11:42 AM
03sierraslt's Avatar
Originally Posted by Y-B-Slow
I have had the NW "boosted" 102 with X-link on a TVS2300 for a year now no issues so far, tuned by Atomic
get your blower rpm up to around 21,000-22,000 and let me know what it does. I was at 22,200. It happened as low as 20,800
they work until you start pushing them hard.
if you scan commanded vs a tail TPS you can see it start to happen before it goes into REP. P59 cannot tune around this.
Old Apr 20, 2020 | 12:17 PM
terravast4's Avatar
what pulley are you running and how much boost are you seeing?
Old Apr 20, 2020 | 02:37 PM
For the record if I turned it down to 19,000 or so blower rpm it didn’t act up.
I doubt with a 5.3 and a small cam your turning over 20k blower rpm.
Old Apr 21, 2020 | 08:00 AM
terravast4's Avatar
THIS is very helpful information!!
Old Apr 21, 2020 | 12:15 PM
Y-B-Slow's Avatar
I bet it would start acting up then too. I know you have been through this all already and ended up switching to a cable tb to get around it. I was just answering the OP's question that yes you can use a NW102 with an X-link and citing what I'm using it for.
My signature is out of date, it is now a 370 with dart 250 heads and an appropriate cam. I'm not spinning it that hard yet but ill get a look at my logs and let you guys know what I am seeing for boost, I haven't had the truck out yet this season.
Old Apr 21, 2020 | 12:17 PM
terravast4's Avatar
I am gonna run the 2.7 pulley with the 10% overdrive and not rev over 6400 rpm so the blower will be spinning in the low 19,000's. Hopefully the ported blower snout and the 1" phenolic spacer will help the air flow.
Old Apr 22, 2020 | 05:04 PM
xxch0dyxx's Avatar
Similar, though right now I have 2.9" until I get the blower ported. Be around 19000rpm blower speed. May or may not be worth the $$ to get one...
Old May 24, 2020 | 01:08 PM
DrX's Avatar
DrX
102's or LS3 90mm clones that use magnetic sensors are not compatible with the truck TAC module. For one thing, the 5V reference circuit is inadequate to power the magnetic sensor.
Nick Williams 102 works with the gold version X-Link. I think the issues with the 102's at higher boost levels with a blower are due to the current draw. Typical max allowed current is 6 amps. Exceed that and the throttle will shut down.
Here are a 102 and a LS3 clone with magnetic sensors. Last pic is a 102 that uses a contact type sensor as in GM TBs.
Old May 24, 2020 | 04:36 PM
smokeshow's Avatar
Mod with training wheels
Sounds like an external power source is in order.
Old May 24, 2020 | 09:31 PM
DrX's Avatar
DrX
There also needs to be continuity through the sensor.
BlackGMC
Apr 8, 2018 08:52 PM
Matt331
May 8, 2015 06:23 PM
Fastcount03
Feb 10, 2013 09:37 PM
joeyc125
Jul 29, 2011 11:59 AM
ryanvv355
Jan 30, 2010 08:15 PM
