100% vs 80/20 meth?
Old Aug 15, 2014 | 02:43 PM
BlackGMC's Avatar
Resident Retard
Default 100% vs 80/20 meth?
I am about to refill my meth jug and now that i have a meth kit that will support 100% meth i was just wondering what the advantages are to switching to 100%.
Old Aug 15, 2014 | 03:03 PM
Vortec350ss's Avatar
Its just a higher concentration of fuel. I think that in theory it should cool better, but i have heard some results that said otherwise. In theory it should allow for more timing, but will require a slightly lower AFR on your gauge because meth likes a richer lambda at max power. I'm still new to the meth game so I certainly can't tell you how much more timing you can play with etc... but that's what I would expect going into it.
What do you target for AFR now while at max boost?
Old Aug 15, 2014 | 03:07 PM
BlackGMC's Avatar
Resident Retard
I target 11.4 now and i am running 16* of timing at 10psi. This is on a 10.0 CR lq9.
Old Aug 15, 2014 | 03:08 PM
oakley6575's Avatar
I don't think you will see or notice any benefit from where you are now but it should give you just that much more cushion in your tune. I'd run 100 meth if it was mine.
Old Aug 15, 2014 | 03:12 PM
BlackGMC's Avatar
Resident Retard
I plan to switch next fill up for the simple reason of not having to mix the meth/water because i am lazy.
Old Aug 15, 2014 | 03:33 PM
TrickTurbo's Avatar
Truck Sponsor
If its not needed.
You shouldn't see any difference.
Looking forward to seeing.
turbo6c3
Oct 5, 2015 06:11 PM
JordanH
Oct 3, 2015 03:59 PM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
